Joining multiple spaces together
HI DIAL Team,
As you know DIALux evo allows us to change the height of particular space to inlcude areas / objects and luminaires etc. from above storeys. Now in real life that does not work for all types of applications as there are instances where space below is smaller/differt size or shape than the one above etc.
Was wondering if it would be possible to instead change the height of the particular space to select multiple spaces and then JOINING them together? That way it would be more intuitive and would help creatind / designing more complex staircases / halls etc.
Basically what IF ground floor was smaller size than upper ones? It would create a space of the size of the bottom ground floor and NOT covering everything above.....
Thanks
9
1 reply
