It would be helpful to create different variations of a lighting designs within one project file (similar to the possibility in Dialux 4,13). For example, if I want to compare two products (or two different arrangements...), I can create an alternative second lighting design for a defined space. After calculations are performed, results can be documented in one PDF. This would help greatly in the project development process.
Create Variations of Lighting Designs - One Project File, One Documentation File
2
