Emergency lighting calculation surfaces -- General improvements
Please add the following:
Emergency Paths should be available to Outdoors to calculate the Emergency Lighting to reach the defined collection Point. Please implement a feature to create calculation surfaces in Outdoors.
In Germany, a Norm requires Planners to check for any Fire Extinguisher or Manual Fire Alarm to confirm if they have 5lx Emin on their cover. The same applies to Fire Hydrants, First Aid, Evacuation Plans etc.
Sadly in the current Dialux Version there is no Vertical Calculation Surfaceto calculate it. Instead, the workaround currently is to go in regular Lighting Calculation and place normal calculation surfaces. It would be greatly appreciated to implement Emergency Lighting calculation surfaces that behave similar to the regular calculation areas but only show up for the Emergency Lighting. Perhaps this could be its own Element instead and implement the 5lx Emin requirement directly to the calc. surface so it shows up red or green in the overview browser on the right side of DIALUX.
2
