IFCSpace import
Delivered
I use Dialux on huge projects with complex rooms and civil elements. The rooms are systematically poorly recognized by Dialux, which unfortunately makes Dialux unusable in this context.
It would be very relevant to have an option to be able to choose, during IFC import, if IFCSpace type elements can be used to define rooms in Dialux, instead of the automatic recognition algorithm.
In our case, this would export the rooms with the exact geometry (which is already defined in the source software), and instantly fix the problem.
Thanks
5
