Move luminaires exact distances
Today if you want to move a luminaire a certain set distance, there's no easy way to do it. You can use the coordinate system, but that's not user friendly or quick. You can also create grids/guidelines but that also is a bit time consuming.
Would be fantastic if there was a function, when you're moving/dragging luminaires, you could get a preview of how far you've moved the luminaire/s. See attached picture for how it could look like.
You already have the function today in the program, for example when drawing luminaire arrangements, you get a preview of the distance between the luminaires, but also the length/width of arrangement.
Would be amazing if you could implement this. Otherwise I'd gladly accept suggestions on how you think the users should move luminaires certain distances.
9
