Show the demanded uniformity from NEN13201 in P-classes in report
When calculating a P-class in the street lighting mode, I would like to be able to show the demanded uniformity is met (preferable with a green check like the other values).
I made an example to illustrate what our clients are looking for in lighting calculation results.
Also, since some other demands (for example from tunnel lighting guidelines or local policies) have additional demanded values for uniformity, I would like to be able to change this preset uniformity demand in the P-class calculation, the same way I can do for the other values like Egem, Emin and Ev,min.
6
1 reply
