Hi DIAL Team,
When doing UGR calculations on a complex projects, sometimes the high values you achieve are difficult to find from which luminaire position it is comming from just by looking at the UGR graph available on the documentation.
Would it be possible to show either a pointer or highlight a particular luminaire from which we`re getting the high UGR values so then we`ll be able to adjust our design / calculation immediately?
This would cut on time spent on searching for the luminaire causing issues + with complex project it will reduce calculation time significantly.
Additionally to above it would be great to have an indicator of the viewing angle as well directly implemented in the 2D/3D view.
Many thanks in advance!
