Calculation surface height vs. actual measuring height
One of my clients pointed out an issue in the Dialux reports.
We did an outdoor park lighting project and they required calculations on the pathways and stairways.
According to AS/NZS 1158, the measuring height of horizontal illuminance should be 0m and 1.5m in case of vertical illuminance.
I created a sloped calculation surface just above the stairs and measured horizontal and vertical illuminances. The offset heights were set to 0m and 1.5m, but in the documentation, I couldn't find any option to show the actual measuring height, there is only the height of the calculation surface which was in our case 0.919m (since it was a sloped surface)
Is there any way to show the actual measuring height in the reports, instead of the height of the calculation surface?
Would it be possible to show the dimension lines in millimeters instead of centimeters??
2
1 reply
