Hi, from some reason I´m not able to make cuts to the floor/ceiling between two storeys. I can cut all the walls, roof and ground floor (but only in "whole building 3D view mode, what is also a bit strange as before I could make cuts even in a floor or room view mode). But the main issue is there is no way how to cut the floor/ceiling between two storeys. EVO file attached.
