Daylight calculation - DIN reference
Good evening,
I am working on a daylight calculation and I want to collect the daylight factor and cross-check it against table A.3 of EN 17037.
How are the values Dm, Dmin and Dmax calculated by the software?
Following the standard's specification, a border strip of 0.5 meters along the walls must be excluded from consideration. The measurement grid must be every 0.3 meters and have a measurement point height of 0.85 meters.
The standard daylight factor grid seems slightly different. According to which standard is it calibrated?
Thank you
Best reply by Alessandra
Hello Daniel,
thank you for your support.
Cheers,
Alessandra
View original
6
