Daylight-relevant builing openings & Materials
13
OS Name Microsoft: Windows 11 Pro Version: 10.0.26100 Build 26100 OS Manufacturer: Microsoft Corporation System Manufacturer: HP System Model: HP Z1 G9 Tower Desktop PC System Type: x64-based PC Processor: 12th Gen Intel(R) Core(TM) i9-12900, 2400 Mhz, 16 Core(s), 24 Logical Processor(s)
A daylight calculation is not possible without daylight relevant building openings.
Hello,
The building has about seven to eight floors, and we would like to review the daylight effect from the dome-style skylight on the roof to the spaces.
If you use the “Apertures” tool, daylight calculation becomes straightforward, but it doesn’t apply to objects. Therefore, I tried using the “Materials” tool by creating a glass material (Transparent, Reflection factor 90, Degree of transmission 90, Refractive index 1.5). However, I received the message: “A daylight calculation is not possible without daylight relevant building openings.”
Is it possible to use the “Materials” function to calculate daylight?
Thank you!
