DIALux 12.1 (with Hotfix applied) crashes on startup
I've been having an issue with launching DIALux. It does not display anything in the window and displays the following error when attempting a task kill. The installer was downloaded three days ago, so the Hotfix for the imperial units issue should have been applied. Unfortunately, reinstalling the software did not solve this problem.
Edit (Mar 22 15:38 PM GMT): Reinstalling the redistribution package or restarting the computer did not solve the problem.
System.NullReferenceException
Object reference not set to an instance of an object.
   at Dial.Dialux.Gui.MainWindow.get_IsGuiLocked()
   at Dial.Dialux.Gui.MainWindow.OnClosing(Object sender, CancelEventArgs args)
   at System.Windows.Window.OnClosing(CancelEventArgs e)
   at System.Windows.Window.WmClose()
   at System.Windows.Window.WindowFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.PublicHooksFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
OS Version: Windows 10 Home 64 bit 10.0.19045
OS Language: Japanese
Processor: Intel i7-11390H
Graphics Driver: Intel Iris Xe Graphics 31.0.101.4502
Application: DIALux_x64.exe
.NET Version: 6.0.28
VC++ Version: 2015-2022 Redistributable x64 14.38.33135
MS Desktop Rntime Version: 6.0.27.33320
Faulting application name: DIALux_x64.exe, version: 5.12.1.7275, time stamp: 0x65310000
Faulting module name: KERNELBASE.dll, version: 10.0.19041.3996, time stamp: 0xb756c9ff
Exception code: 0xc000041d
Fault offset: 0x000000000002cf19
Faulting process id: 0x3ce0
Faulting application start time: 0x01da7c69a7361861
Faulting application path: C:\Program Files\DIAL GmbH\DIALux\DIALux_x64.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Untreated exception: Object reference not set to an instance of an object.
Please let me know if there is any other information needed to identify the problem.
Thank you in advance!
2
