How can I dimmer down the absorbed power of a lamp? For example: I want to install a 430 W product, but then I want to control it and make it works at its 70%, without touching the maintenance factor. Is it possible?
Thank you all in advance!
you need to create a "Luminarie Group" an put the luminarie that you want to dimming in that group. The last step is set your % of dimming.
