Extending length or size of IES file
I have been using Dialuxevo for 7 years now and still do not see how to manipulate the ies file size once it is loaded. I also use Agi32, so if I need to do some complicated linear lighting, I must stick with AGI32. I am just wondering if Dialuxevo fixed this simple but very important issue for lighting designers.
If not, I am just curious if the dialux evo team realizes that the ies files we are getting from the manufacturers are not always the size or the length we need.
How do you others get around this problem if you need to use the same ies file type but different lengths on the same project?
2
