When performing glare rating calculations in DIALux evo using EN 12464 and CIE 112, I obtained different glare values.
If the client has not specified a required standard, which standard should be preferred?
When I follow EN 12464, I am unable to achieve the target glare rating. In such cases:
How can the required glare rating be achieved?
What is the ideal observer height and viewing direction?
What tilt angle should be used for the luminaire?
For pole-mounted fixtures with mounting heights of 2.5 m or 3 m:
What observer height should be assumed?
What luminaire tilt angle is recommended?
Additionally:
Which design parameters can be adjusted to achieve the target glare rating?
Why do EN 12464 and CIE 112 produce different glare results?
For better understanding, I have attached the native DIALux file and the comparative PDF
