Hi,
I was planning to purchase pro membership, so right now I activated 30 days trial. I am trying to import IFC drawing using the PRO feature but its not happening.
Its showing the below error.
IALux evo IFC report
This report summarises errors and comments regarding the IFC model listed below. The report can help to uncover issues in the IFC model. In addition to errors in the model itself, it also explains which IFC contents DIALux evo cannot handle and why. This report can be useful for all roles involved in the BIM process. It supports the collaboration between BIM coordinators, architects and all planners who are responsible for the building equipment.
IFC File
File Name: CENTRAL 7 Arch IFC.ifc
File Size: 88917 KB
Schema Version: IFC2X3
Application Identifier: Revit
Application FullName: Autodesk Revit 2023 (ENG)
Application Version: 2023
Notes
Info: Imported with DIALux Version: 5.12.0.5620
Info: Site has no place name "Default" (IfcSite -> Entity: 197 Id: 1tBqqckUH8_hnKXCA5VIsY)
Info: Storey contains no walls. But it contains a roof "BASEMENT -03" (IfcBuildingStorey -> Entity: 120 Id: 25z_kU8TDDvxSqWVO98k8e)
Error: Ifc geometry creation completed with error
Info: Ifc Import aborted with error
