IFC UPLOAD
Dear Dial Team,
We have encountered an issue with IFC files only working on slim files or demo versions. In reality, it is impractical to ask each planner in a BIM project to reduce their plans.
Could you implement a feature in the choices section that indicates when the file is sufficiently reduced?
In our current BIM project, we had to revert to using REVIT and performed only sections of regular calculations.
How soon can we expect an upgrade from DIAL that will better support our workflow? As it stands, this limitation is hindering our ability to work effectively with BIM.
Thank you for your attention to this matter.
1 reply
