Missing Polyline with Linewidth from DWG when Import Plan to Dialux
Hi,
I recently notice that when I Import Plan to Dialux, polyline used in the DWG file will not show up in Dialux.
I have tried saving in .dxf and .dwg as well, and it result the same. Tried saving in 2013 .dwg and 2018 .dwg file as well. Each file type still result the same missing polyline with linewidth when imported to Dialux.
I am using the latest version of Dialux Version 5.12.1.7323.
Here is a sample of the .dwg file. Once imported in, you can see that those polyline with linewidth will not show up in Dialux, whereas those with 0 linewidth still can.
Is there a workaround for this? As I have plenty of drawing using polyline with linewidth and it do not show up in Dialux when I imported them.
Screenshot from Dialux
Screenshot from AutoCAD
Drawing2.dwg
33.64KB
