Product datasheet doesn't show up when generating the project's documentation
Hi guys!
I have recently installed Evo version 13.0.
When generating the project documentation, I no longer have the option to select the product datasheets. When I had the previous version I didn't have this problem.
Has this happen to any of you? Do you know how to solve this problem?
Thank you very much.
Best reply by Kolja
  1. Close DIALux.
  2. Open the Folder C:\Users\<User name>\AppData\Local\DIAL GmbH\DIALux\ <(User name> is the user name you are logged in to) in the Windows Explorer. There should be a "Output" folder, just right click it and select rename and enter any new name.
  3. Start DIALux.
The colleague was already able to find and fix the cause of the problem; the next patch will solve the problem even without the workaround.
View original
