Hi there, I'm currently scoping out different softwares for a client of mine who's a lighting designer. Here's some questions I have about the software:
1: Are you only able to use lighting products in the Dialux product library? If I wanted to use specs from a product outside of the Dialux product library, would that be a possibility?
2: When you import a DWG into Dialux, are you able to edit it in the software itself? And how capable is Dialux at exporting DWGs?
Thanks in advance!
