Change order rooms output
Hi everyone,
Is it possible to change the order of the rooms in the output?
For example, I work with a structure of rooms that I name 1.1 xxx / 1.2 xxx / 1.3xxx / 2.1xxx etc. in order of importance in my project.
However, some less important rooms are located in the basement, for example, and therefore appear first in the report when in fact they are at the end of my structure and are less important to my customer.
Can I change the order in which the rooms appear in the output by alphabetical order based on the name of the room, or change the order in which the levels appear (groundlevel before basement)?
Thank you
Guerric
1 reply
