I have been tasked to create a lighting study with calculations. This is an offshore oil and gas platform. Other specifications include specific lights (Luminaire Parts List No. Pieces Designation 1 4 Appleton CLED 5000LM, CLEAR GLASS, 5000K, 120-277VAC 2 13 Appleton LELED3CXXXXD Appleton Linmaster LED luminaire, Zone 1, 700mm, 3000 lm, 5000K, Diffused Polycarbonate , Standard version 3 32 Appleton LELED5CXXXXD Appleton Linmaster LED luminaire, Zone 1, 1300mm, 5000 lm, 5000K, Diffused Polycarbonate , Standard version) The layout DWG plan is provided and i do not know how to get started. The only thing i have done is to load the file, from there i do not know how to proceed, Please help.
Let me share the scope of the study
( The study includes estimation of the illumination level as lux on the environment, primarily on the ocean surface and its visibility on a long range. The illumination level is produced as isolux contours which is an output from the lighting calculation model DIALux version 4.13. The typical model input includes the following:
路聽聽聽聽聽聽聽聽 Lux Intensity levels at 0-meter above the sea level at a horizontal plane, is used as a basis for lighting system.聽
路聽聽聽聽聽聽聽聽 Luminaire list with layout plan of the platform.
路聽聽聽聽聽聽聽聽 Lighting lux levels as provided in the lighting specifications
The output of the model will then be assessing the impact on the environmental receptors both common and sensitive)
