How do you import Autodesk Revit models into DIALux?
Are you working with Revit and want to use your model in DIALux?
This guide explains how to correctly export Revit models as IFC files right now – and highlights typical points to watch out for.
Export the Revit model as IFC
Start by exporting your Revit model: Revit Menu → File → Export → IFC
Especially in larger projects, it’s common to work with multiple sub-models (e.g., architecture, MEP, structural engineering) that are combined into one complete model. These are known as federated models. Each sub-model is its own Revit file.
Sub-models are exported with separate locations
The problem:
When exporting federated models, Revit can automatically assign a separate location to each sub-model in the IFC file.
The result:
DIALux only processes one location per IFC file.
Other sub-models are ignored – large parts of your building might be missing!
How to avoid this:
Ensure that all linked models are assigned the same location during export:
Adjust export setup → Additional content → Linked files → ✅ Export using shared location
Example:
If you export your architectural model and MEP model separately without enabling this setting, DIALux may only display the building envelope – but no installations, ceilings, or technical spaces.
Incorrect use of the “Building Storey” checkbox
The problem:
In Revit, storeys are defined by levels (cut planes). If you activate the “Building Storey” checkbox, a storey is automatically generated in the IFC file during export.
However, this checkbox is often also activated for element groups that do not represent actual storeys – for example, handrails, furniture, or ventilation components.
The result:
This creates unnecessary or nested storeys that confuse or complicate navigation and structural calculation in DIALux.
Typical examples:
  • A handrail is suddenly interpreted as its own storey.
  • Furniture groups become separate floors in the IFC structure.
  • MEP components mistakenly generate “intermediate levels.”
Correct approach:
Check in Revit which elements truly define a storey. For components that merely sit on a level, you should not activate the checkbox.
Best practice:
Only mark actual floors such as “Ground Floor,” “Upper Floor,” or “Roof” as storeys.
Do not activate the checkbox for furniture, stairs, or MEP groups.
7
