Download now: DIALux evo 11.1
++++++ Update ++++++
DIALux evo 11.1 is now available for download. Many new practical features await you. Here you get a short overview. Below, these and more new features are described in more detail. ben.
  • Get a preview of the inserted images directly during import.
  • Use new handy shortcuts
  • You can switch between the values energy consumption, LENI, costs and CO² emission directly at the energy saving meter.
  • The object coordinate system is placed in the center of the floor by default
  • Design extrusion bodies even finer
Click here to download DIALux evo 11.1 for free.
In the settings for working planes you can configure whether they should be created automatically for areas and rooms or not. Hereby you can also create rooms "empty". This setting is available for exterior and interior separately.
The F12 key can be used to repeat the last tool action used by pressing a key. This is especially helpful for actions that have to be executed again.
In addition, we have compiled further helpful hotkeys for many program functions for you. You can get a detailed overview in this handy PDF.😊
You will be able to enter color configurations as the web format #Hexvalue.
It is also possible to configure sections appropriately before drawing them. When you click on sections in CAD, the values of the last clicked section are always used as the basis for the next construction.
When you import images, DIALux displays a new selection dialog with the current contents of the clipboard to help you. This gives you a preview to check if the image is what you want. For example, you can load images as content of the documentation, as a plan, but also as material.
In addition, you will soon be able to set whether light textures and results should be automatically discarded when project changes are made. The highlight here is that DIALux will no longer display the prompt to discard the results.
Set a name for the default editor. For new projects, this name is automatically applied to the project. Default page selection for presentation and table.
In addition, we have made existing functions even better for you 😊
You are able to switch between energy consumption, LENI, costs and CO² emissions directly on the tachometer.
DIALux places the object coordinate system in the center of the floor surface by default. This guarantees that the grouped objects are also on the floor when inserted and, depending on the design, are no longer tilted.
You can design extrusion bodies much finer, down to the mm range.
We are looking forward to your feedback 😊
57
